I am planning to install a windlass in my Hunter 37.5. I would like to use an all chain 200 ft rode,and be able to add rope if required. I would like to be able to have a 5:1 to 7:1 scope, for depths around 50 ft. I collected the following info so far: A vertical windlass is the most indicated, mounted aft of the anchor well and near the starboard edge., to better line up with the anchor chain channel, that runs in the starboard edge of the bow. I would appreciate inputs and photos of the installation, the windlass model used, chain type and size, should I connect the wires to the 3 house batteries bank I have, wire size used, etc. And finally,do you have to help coiling manually the anchor rode. I would appreciate any inputs you might have. I am not receiving any good inputs from boat yards, and marine stores.
