Mast Rake Aft?
Bob: Check the rake of the mast to the aft. Bend in the mast will help you to flatten the main to depower. However, aft rake in the mast will give you more weather helm than you want in heavy conditions. Slanting the stick back increases the amount of sail behind the keel and causes her to push into the wind. The 29.5 already has a bunch of main sail behind the mast. As Justin suggested, balance is the key. The jib on the 29.5 is not large. I would think that more jib in the conditions you describe might help with that balance. The big roachy main that helps you move so well in light breezes requires some finesse in heavy air. I have noticed that many 29.5 sailors on our lake ease the mainsheet slightly and pull the boom to windward allowing the top of the main to twist, spilling air and helping to keep the boat on her feet. On our 33.5 letting the helm come up a little closer into the wind in gusts also helps keep her flatter and reduces the need for pushing the rudder hard over. If you are still overpowered, try going to the second reef in the main. Our boat is at least as fast when we have her comfortably under control, as when we are fighting like hell with the rail in the water. Not to mention there is less strain on the rig (& the nerves). Check out Brian Toss Rigging - www.briantoss.com - for tuning information. Good luck, Ron
