Thanks for the site comment & Charlie's right
Charlie, thanks for the F235 site comment (and thanks for the mention, Neil). There is actually much to be added as well; the entire site started as a personal buyer's guide of info for me while looking at an F235 in Charleston, SC. Obviously, it got out of hand...heh. Indeed, there is a link to this forum and F235 space on the site on the links page.The dedicated F235 forum was a recent addition and it's really taken off with over 1500 posts and 66 members. Of course, I still peruse this place as well, as it has an exellent database with active membership.I agree with everything you said about the swing keel except to say most, if not all, were sold in Europe. As Charley noted, you must maintain the underwater parts especially, and if left in salt water, this becomes even more critical. Two things strike me as critical with the F235 swing keel. One is that it puts the already DEEP rudder more at risk if motoring with swing keel UP. This would not be as big a deal if it wasnt for the fact that the rudder DOES NOT kick up and the Beneteau F235 transom to hull joint is not as robust as it should be. Of course, the European F235 might be made slightly different than the ones made in SC, USA. See info on this on my site. The second problem is the fact that you DO have more parts to maintain and if something DOES let go while the keel is in the up position, there is a chance it will drop with its full weight to fully extended position. I dont know of the specifics of the F235 Swing but do know this has happened with Catalinas and other boats, sometimes actually causing the boat to be holed. Dont mean to alarm you but this is why PREVENTATIVE measures are the best here, keeping your swing keel parts in good shape.I will try to find some more info on the swing keel versions as several members do have these but have not posted as much. Another source is the beneteau-owners.com site which has some comments here in the library. Also, the First 210 has the swing keel so there will be info on this model. Kellyhttp://beneteau235.com/F235 Forumshttp://beneteau235.com/forum/
