WIND INSTRUMENT STICKING
RICH
The wind direction indicator at the top of my mast is sticking. (Not my windex but the one attached to the ST50 ). It will stick until I get up to about 10knots apparent. Any advice on what to lube it with? I only want to go up the mast once to do this. Thanks for any suggetions.
Bob Fuller
Lubrication
I used a silicone based lubrication when I did mine. Since then I've heard that a Teflon based lubricant would probably be better. Sorry it's not a definitive answer. I'm sure that others will have good advice as well. What method are you using to get up the mast easily?
Rich
Bosun's Chair
Bob, I have a Bosun's chair that I use to go up. Usually I go up with the main halyard and use the spinnaker halyard as a safety. I had a power winch installed last year so my wife doesn't have to work so hard anymore. Thanks for the response. I'll look into the teflon option.
