Better Hookup
I'd run the output + side of the wind generator either to the "common" (middle lug) of the House bank switch or to a spot on the back of your breaker panel. Going to the HB switch will allow you to selectively charge either house battery or both depending on the position selected. The - side of the wind generator needs to be tied into a DC 12v ground that is always connected to the - on the battery post or engine. On my P42 (a 1993 which I just purchased), I am currently going to replace the ON/Off Starter Battery switch with a 3 way type so that I can choose and direct the alternator and all other charging to the Starter Battery (Position 1), the House Bank (Position 2) or Both. The House Bank led will then be further sub-divided by the existing switch between House 1, House 2, or both. This will also allow me to easily select my house batteries if necessary to start the engine or generator. If you adopt this set up then the Wind Generator + and all other 12v+ charging should run to the "common" lug on the new switch. It is not a good idea however to charge the starter battery (a 24/27 not the same capacity as the HB)and HB batteries together as the Charging sensing cicuits will sense the battery level with the highest charge and react accordingly. Thus you have to manually switch to where you want/need the charge to go. Charging on Both (ie. Starter and HB) will will not result in completely charging the HB. You can use a battery isolater to accomplish this automatically, but you pay a penalty by the voltage reduction from the isolator. Note: The new Starter/HB Battery switch should never be turned to "Off" with the engine running as this will blow the diodes in the alternator. But this would happen with the existing Starter On/Off switch too. This setup also assumes that you have batteries of the same type (e.g. all wet cell and not a mixture). Good luck, if you have different battery types as they all have different and specific charging rate requirements. Hope this helps - Don
