Wind gear
19
Hunter Passage 42 Manly
Hi all
We have a hunter CC 42.6, is it possible to replace the cable in the mast with out taking down the mast
Cheers
Mark
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Maybe
But you will need to go up the mast and than tie really good a new wire or line to the old wire and pull the old line down and out with a new wire or line to use for a new wire.
Nick
Oct 11, 2008
19
Hi Nick
Thanks, I have heard that the old cables might be glued inside a conduit. I was hoping some one else has done it
Cheers
Mark
Dec 19, 2006
5,832
If the wires do run into conduit I don't think it is glued,I did run some cables for radar and wind machine on my old Hunter back in 2001 and where there was nnot conduit I think maybe a added some silicon but that was wires exposed on the sside of the sail track I think,was a long time ago and running the radar wire was inside the mast and no glue was used.
Nick
eianm
Jul 7, 2010
523
Hunter 42 Sydney
in my H42 I replaced TV anetena coax last year at same time as I replaced the rigging- there was no conduit- it all ran insiode the mast section- should pull through easily. The big deal is likely to be at the deck step- mine was packed solid with silicone ( packed solid around all wires- I guess to fix water leaks) - that took hours to clean out and only AFTER to had stepped the mast down.
Good luck!
Oct 11, 2008
19
Hi Eianm
Thanks for the info, will change the cables when we get back from the Whitsunday Island
Cheers
Mark
Oct 11, 2008
19
Nick
Cheers
Mark
