Winchers? Poor man’s self tailing winches
May 7, 2023
85
catalina 27 lake st clair
These “add ons” to regular winches make them “kind of” self tailing. They cost about $100. I’m waiting on my self tailing Lewmar 40s from west marine but now wondering if I should just do the winchers. Any thoughts ? I have an 84 Catalina 27.
Joe
Jun 1, 2004
8,260
Don't waste your money if you expect them to be "self tailing". why? Because there's no stripper arm to peel off the line as you wind it in. Also, for even a foot or so of "self tailing" the drum must be fully wrapped so the underneath, ribbed part of the rings can grab the line. This is time consuming and requires two hands..... so what's the point? Nope... won't work otherwise.
However, if you want to use them as a cleat, or do minor tweaks, they can provide a benefit to halyard winches...but with your primary sheet winches.... no, no, no... not good..imho they actually slow down or inconvenience the operator. Save the $100 for other projects. There's no short cuts here. Enjoy your new ST winches... a very good investment.
Oct 13, 2020
186
catalina C-22 4980 channel islands CA
I agree a waste of $100. I have a set for my Cat22. I took them off after trying them on a couple of outings.
As @Joe explains, winchers at best are tailing assistants. Without the stripper arm you need to tail and remove the line as it is winched in. The girl of the wincher is dependent on the plastic upper/lower pieces retaining their grip on the line. As they age this can become an issue.
Save your money and apply it to proper winches. You’ll be ahead and happier in the long run.
John,
Not in my experience. Had them for ten years on my Catalina 25. Saved enough $$$ to buy an autopilot in 1985! :) I sailed SF Bay with them, FWIW.
Definitely a cost effective substitute. Not exactly the same as STWs but 95% there in my experience.
The amount of misinformation and false disparagement I've read over the years is staggering. Much of it may, I say may, come from people who haven't used them. Example: don't use the slot at the top between the two discs for anything at all. Some people think you have to fit the tail of the sheet in there. RTFM...
I can understand your insight.
The boat I have came with non self tailing winches. Sailing solo and wanting to minimize my expenses, I examined the winchers as a solution. On the 22 Barient, I did a test. In light breezes I thought maybe. When the breeze stiffened I was dissatisfied. Sailing in 30 knot breezes on the Juan de Fuca I felt rewarded for deciding to take advantage of the BOGO deal for the pair of ST 45’s by Lewmar. My boat is different from the OP and my opinion is biased based on the experience.
We each must evaluate our needs and the budget we have to address our sailing.
Likes: Ward H
Joe
Jun 1, 2004
8,260
Well, of course, Stu and I have made the same contrasting comments about this product many, many times over the years. He likes 'em, I don't. ( and I have certainly given them a fair trial....leaving them on my halyard winches for a year or two back in the old days.) The simply fact is they will not turn a standard winch into a self- tailing one... which is the promotional hook.... so I"m prone to re classify, or at the very least re define, what they are.... by removing the "self tailing" reference.
May 7, 2012
1,577
Hunter e33 Maple Bay, BC
That's true, and I'm so glad that we're still friends, can still discuss differences civilly, and are both still here!
:):beer::beer:
  • Ha
Sharing magic beers. What a concept. Makes one feel all warm and fuzzy. I like it.
Jan 26, 2019
70
Catalina 30, mkI 2462 Waukegan, IL
I put a pair of Winchers on my primary jib winches (size 40's) a few years ago. I did leave them on. HOWEVER, I am in the same camp as others--they do NOT make a winch self-tailing. I have used them in a pinch to hold a line for a bit. They do work as a cleat in light to moderate air. If I was just a little more serious about things, then I too would take advantage of an annual 2 for one winch sale.
Joe
Jun 1, 2004
8,260
Yup, good point. Since the wincher topic is the only thing I can recall that we've ever disagreed, we can't claim the pragmatism award for boat beefs, I just know that the expression of differing opinions among in the community makes us stronger in mind and spirit. (whew!, hope that wasn't too heavy, but y'all get what I'm sayin"... right?)
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
I had Winchers on the primary sheet winches on my last boat. They didn't work for self tailing but, as mentioned above, they would hold the sheet in moderate wind. They did work well for protecting against bruising.
I replaced the winches with self tailing and that was a huge upgrade.
Sep 24, 2018
3,992
Catalina 30 MKIII Chicago
They still require two hands so there isn't a big advantage. I'd buy some cam cleats or horn cleats like this. If using a cleat, simply laying the line across the cleat to form an X or a loop instead of a U shape, can add extra holding power. I hope that make sense. Maybe someone can better explain what I'm talking about
