stubborn winch
Frogvalley, Have a "25" and winch would not release(she had not been in the water for +/- 10 years).With winch handle off,sprayed visible shaft well with WD-40,allowed to soak? for a few hours,then ratcheted winch one notch then, released rapidly,(again&again).After a period of time the friction winch began to cooperate.A bit of sweat involved here,much perserverence.That is what worked for me.Now I am able to raise and lower keel.Next, will jack up forward end of keel to remove pressure from bolt and remove.Will let you know size and washers required.Plan to lower forward end of keel completely,then lower aft end with winch.If sucessful,will refinish(epoxy) keel.Best of luck. popeye
