Winch Works
Hi John,Ocean Winches dating from 1995 or newer are super easy and require no tools to take apart and service. Service manuals are available at www.lewmar.com in .pdf format. Hard copies are available by request.I recommend buying the Lewmar Winch Service package from your local distributer. It will include spare pawls, springs, some light gear grease, pawl spring oil, and a nifty brush for applying it all. The part number is 19701500. It should service 2-3 winches.Make sure to remove all grease built up in the pawl springs and pockets. The grease build up can cause the springs to stick. Also make sure the pawls are seated correctly in the pawl pocket. The kit will include extra pawls to replace those that may have worn.
