I have a 9.8 Nissan...
... which is the same as the Tohatsu, and as Stephen suggests, I am using a motor mount. It does move the mnotor back, which it gives it more movement, but then the tiller (which does tilt up) is so far away that you have to get into the engine well to reach it. To make it easier to control, I have fitter a tiller extension to it and now I can reach it from inside the cockpit. However, it still makes it difficult to steer with both the rudder and the motor at the same time, which you need to do in tight spaces. So now I am looking at the EZ-Steer system that allows to connect the outboard to the rudder and then you just steer with the rudder. Has anyone had any experience with this syetm on a 26S (or D or C)?I have also fitted a Power Thruster to the outboard and it serves two purposes, the first for what it was intended, and the second as a guard against the rudder and the prop coming into contact.
