Will this work for fiberglassing a thru-hull?
Jul 5, 2005
217
Beneteau 361 Sandusky Harbor Marina
Hi All!
I've started wading into the process of updating my new-to-me 1975 C22, and one of the major projects I'm hoping to complete before April 1 is to replace the original gate valve thru-hull with a proper ball valve (I think that's what it's called anyway). I had seen a thread on here where Minnesail (I think) fiberglassed over his original gate valve thru-hull and cut a new hole for the ball valve thru-hull a few inches to starboard of the original, so that's what I was planning to do too.
I have almost no experience with fiberglassing, but it doesn't look too complicated. I don't have a West Marine or other type store locally so I have to order the materials. Is this the product I need to order to patch the old gate valve thru-hull hole?
Thanks so much for any help! :)
dmax
Jul 29, 2018
980
O'Day 35 Buzzards Bay
Fiberglassing a hole in the bottom of your boat might not be the best first project you want to do. There's lots of info out there on the proper way to do it, watch this video for an idea:
Why not use the existing hole, it's a lot easier even if you have to enlarge it.
Jul 5, 2005
217
Dmax, I will if I can. I don't know how easily I'll be able to get the old gate valve off while still being able to preserve a surface suitable to mount a new ball valve. I assume that's why Minnesail didn't use the existing hole. you can see his installation in the thread below.
dmax
Jul 29, 2018
980
You should be able to get that old through-hull out - use a reciprocating saw with a metal blade (or a Dremel tool if space is too tight) and cut it off. On mine, I cut the nut in half and chiseled it off. Just cut metal and not the fiberglass and you should be ok. Usually takes 5-10 minutes. If you haven't already, read MaineSail's advice on through hulls before starting:
Likes: Richard19068
Jun 11, 2004
1,633
Oday 31 Redondo Beach
You can also use a grinder to grind off the mushroom head on the outside of the hull.
Jul 5, 2005
217
Good thought, Richard. If you look at my picture though, you'll see the gate valve thru-hull is in the swing keel recess. I don't think I'd be able to attack this from the outside for that reason, as well as because the swing keel itself is likely in the way.
AaronD
Aug 10, 2014
723
Catalina 22 9874 Newberg, OR / Olympia, WA
@Ben4195: You definitely want to replace the gate valve with a ball valve; some people have found that screwing a ball valve onto the original pipe works great; others found that the original pipe embedded in the hull isn't well bonded :yikes: Mine was probably fine, but I don't know how I could have told the difference without reefing on the threaded pipe, thus destroying the threads... Which was fine, I was already planning the replacement. See my notes and pictures if they're helpful.
I sealed over the original through hull by epoxying a stack of fiberglass (G10) circles into the hole, followed by a few layers of fiberglass tape top and bottom. I haven't ever painted the bottom, but it doesn't see any UV there anyway (and I don't care if my keel trunk looks pretty :)).
And yes, West System epoxy is a great product for this. There are other good brands too, but I'm happy to support West.
