Good points, all.
My A-4 is happy at my normal powering RPM of 70% max. rating. I figure the boat was designed with the Atomic 4 in mind and by the time mine was built Catalina had most of 600 chances to refine the prop size if necessary so by then they should have had it pretty well dialed in. If I were in the market for a prop for reasons other than performance (such as damage) I'd consider the Indigo but under the current circumstances I'm not motivated to spend the money.
Regarding the adjustable main jet, it's quite an aftermarket refinement (Moyer) and I'm certain jetting development continues. Again, as it applies to me, I'm perfectly happy with the standard fixed jet. My spark plugs read fine when I change them so what would I hope to improve? The adjustable jet is a necessity for those who choose to add a PCV system. On the Moyer forum my negative opinion of the PCV system is by far in the minority.
With the adjustable jet care has to be taken not to lean out the mix too far, it tends to elevate engine temps and in the extreme can damage valves.
And for the record, I'm fine with diesels. Had one myself in my last boat, a Perkins 4-107. It was a sweet running engine but then again it was a Perkins so it had better be. It's true they are noisier than their gas counterparts but full engine space soundproofing manages it well. Smells are easily managed by keeping things clean. Mine didn't smell.
The only problem I have is with the 'diesel snob' owner who looks down his nose at me because I'm a gasser. Don't deny it, they're out there. I once had a 'big dawg' on this forum offer the starting procedure for an Atomic 4 that ended with, "You turn the key and BOOM." I took him to task the best I could asking what kind of cooking fuel he had on his safe diesel boat, propane?? It was. Gee, a bit hypocritical aren't we? No problem with propane, a fuel with vapors also heavier than air, roughly the same explosive potential as gasoline and stored under pressure yet you'd never own a gas powered boat because they explode? He went on to explain all the safety features propane installations have, solenoid valves, isolated lockers and fume sniffers. Oh I see, you take precautions to keep it safe? (Yes he did) So why then is it assumed I don't do the same with gasoline (safety measures)? It wasn't pretty. In fact, it earned me a rather rude private message exchange with [name withheld] that I was a problem. It wasn't nice that I'd challenged a forum big dawg.
If my boat came with a diesel, no problem but I feel the same about gas, no problem either. There's no denying gas is quieter and by quite a bit.
