Risers for Harken CAM Cleats
Mark Kissel,I like your idea about making teak bases for the CAM cleats. I was going to just purchase the Harken risers (which are only about an inch high), but then I would still have the problem of filling the old holes, not a pleasant thought. Let me make sure I understand what you did: Did you make the risers large enough to cover most all of the flat area adjacent to the rope clutches and then use the old clam cleat holes to secure the riser? How did you attach the new cam cleats to the riser? Are they bolted through the teak or just screwed in? Also, what kind of screw/bolt hardware did you use? Finally, do you (or anyone reading this) know what the backing place that all this hardware is mounted to is made of? Forgive what may be obvious questions but I am a real novice and want to do the job right the first time and avoid an unsightly, or worse, unsafe, installation.Paul Jordan, Mithrandir
