Mark
I recently obtained an older Widgeon that is in pretty good shape except that the hole in the deck through which the mast is inserted is cracked. Some previous owner lost control when stepping the mast. The hole through which the mast is stepped is now s jagged 4 inches in diameter.My question is what's the best way to fix this? I was thinking of cutting a piece of marine plywood and bolting it under the little ledge that forms the structure where the mast whole is located. Then, I was going to lay some fiberglass on top of the ledge.First, is this a fixable problem?Second, is my approach viable?Lastly ,would it be OK to drill through the fiberglass?Any suggestions would be appreciated.Mark
