I have a '79 Widgeon.  The boat is in great condition.  The only problem I have is that the centerboard sticks badly.  It is the centerboard lowered/raised with ropes, rather than the handle used on earlier models.  I usually have to wade out to waist deep water, almost capsize the boat, pull the centerboard down, right the boat, and then sail.Has anyone ever removed the centerboard from a Widgeon?  Is it hard to remove and reinstall with the ropes?  I've asked Rudy Nickerson, and he stated that the centerboards often swell over time, and that removing it, sanding it, refinishing, and reinstalling might work.  Alternatively, I could purchase a new centerboard from Rudy.  I've also read of other Widgeon owners who have simply drilled a hole in the top of the centerboard trunk and used a dowel to "unstick" the CB when they set sail.Any thoughts or advice on trying to repair/replace the CB, or simply to use the dowel method, would be appreciated. TIA!Mark Schneider
