When I flush my 1998 H376, of course, it goes directly to the holding tank. When I am at the dock I pour fresh water into the bowl, then pump. Everything always goes smoothly.
When I am at anchor I use sea water to fill the bowl. I then flip the switch to dry to pump it into the holding tank. At this point it seems like it would be no different than what I do at the dock. However, there is always a lot of pressure when pumping after I have filled the bowl with sea water. When I get back to the dock and switch back to pouring fresh water into the bowl. Everything goes back to normal.
I don't get it.
Any suggestions ?
Thanks,
Jeff, s/v Tango
I don't get it.
Any suggestions ?
Thanks,
Jeff, s/v Tango
