I finally decided to chase down several toe rail leaks on my old H-30. I started from the stern and snugged up almost all of the screws underside with my son holding a screwdriver from the deck. Several were very loose.
This was not all that easy especially since several of the nuts were frozen and several sheared due to obvious corrosion.
Although it's done I have 2 questions.
First why on earth don't sailboat builders use regular hex bolts on deck fittings?
If it looks why not use carriage bolts which would be flush on the deck and would be simple to tighten from the underside?
Am I I crazy?
Am I I crazy?
