Stephen - do you have tell-tales on your mainsail?
99% of the sailors and 'sailing authorities' descripitons of how a sail works is WRONG. Bernoulli doesnt apply, the designer's (concept) of center of effort doesnt apply, there is NO such thing as a *slot effect*, backwinding ISNT, .... your high school physics or science teacher had NO idea, etc. etc. etc. etc. All those 'principles' went into the trash can when aerodynamicists fully examined sails back in the mid 1970s .... and still the 'books' and sailing authors pump out all the WRONG stuff!Without tell-tales applied to the windward and leeward side .... and having them ALL flying straight back it is possible to so disturb the flow 'direction' over a sail that the *dynamic* resultant CE (the sum of all dynamic forces acting on the sail) may have moved so far forward (or even moved to several feet in front of the sail) that caused you to encounter such an adverse helm. Sorry but the air 're-circulates' around a sail and the recirculation may have been so 'off' that that caused the extreme unbalanced helm. Even with the sail apparently 'full', such forces can move where intuition tells you they cant possibly be - all depends on the angle of attack, separation (not a stall !!), and where the 'stagnation streamline' approaches the sail, etc. Aerodynamics is definitely not an 'intuitive' science. If you had tell tales on the lee/windward side (at luff and leech) you could have noticed how the flow was along the windward and leeward sides of the sail to verify that you did indeed have correct flow going on. Without tell tales, there is NO way to reconstruct what happened. Just a guess on my part - was that the leech was separated / 'tripped', you had a huge separation bubble at the luff on the leeside, the leeside may have had its flow separated (not stalled) and only the windward side may have been 'working'. You probably had the boom on the centerline instead of dropping the traveller when one sails with mainsail alone, etc. etc. Cant tell without knowing what was going on with the tell-tales. Its actually quite easy to get the (recirculating) flow going backwards if you dont use tell tales to keep things 'straight'. Don Guilette's "Sail Trim User Guide" etc. is *wonderful* means to keep it all SIMPLE and without having to delve into the mysteries of aerodynamics. For those who want to browse into how a sail ***really*** works go to www.arvelgentry.com then go to the 'magazine article section' and explore "how Sails REALLY work" for a better (true) understanding. Caution this is NOT simple stuff; and, if you 'get' it, you'll definitely say ah-HA! Right after you say ah-ha! you will immediately will rush out and apply tell tales to your sails. BTW a H27 will sail quite well solely on just a genoa even during times when you would have reefed; it just wont point as high. You'll need to really drop that traveller down to make it 'go' with just a mainsail ... and need to 'read' those tell-tales.hope this helps.
