Why I don't have in mast furling.
Feb 11, 2017
6
I've had in mast furling once before on a 43' Gulfstar. It got stuck immediately so I spoke to my sailmaker. He said if I bought a new sail it would be stronger and yet thinner material so it would easily go into the mast. It stuck immediately and got scuffed up trying to get it out. Went back to the sailmaker who suggested a behind the mast furler, identical to my headsail furler. So, another 2.5K into the sail. That worked perfectly for the seven years we owned that boat. Some folks say it doesn't sail as well but I never noticed any difference. I have a friend with a newer 42' Beneteau sloop with in mast furling. It's been a nightmare for him for the ten years he's owned the boat. Here's a little video clip of exactly what happens on these poor people's boat.
JamesG161
Feb 14, 2014
7,752
Hunter 430 Waveland, MS
25 knot winds? You should have been reefing the main.:rolleyes:
Jim...
PS: Tip: the sail was furled incorrectly.
Jun 14, 2010
2,298
Jim...
Never seen that on a roller furled headsail. Worst case the furling line jams or breaks, and you disconnect the sheets to wrap it around the foil manually. Face it -- in-mast reefing is finicky and has its problems. Isn't that Les's point?
Dec 19, 2006
5,821
Hunter 36 Punta Gorda
Is it a Selden Mast and my selden Inmast furling main has a winch on the bottom of the mast and by putting
a winch handle in it you can help unfurl the sail,this happen to me once when I was in a hurry at the dock and furled the sail into the mast very badly and did everything wrong and so when I went to go sailing the sail was stuck but with help and a winch handle in the winch on the bottom of the mast I was able to get the sail out with out doing any damage and than this time made sure to hold pressure on the outhaual allowing the sail go into the mast very smoothly with out any wrinkling and no jaming of the sail.
Nick
Feb 11, 2017
6
I saw a Freedom 44 cat ketch recently that had a power winch for the mizzen halyard. Apparently, the sail bound on something and the winch continued on. It eventually pulled the top third of the sail up the track without the bottom two thirds. Another modern nicety I don't think I'll even wind up with.
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
I watched the video of your friends boat, an old sail with not much life left in it anyway. I have an in mast mail, a bit sticky when we first sailed the boat on purchase in the fall, but hadn't been used much in the last few years.
Oct 13, 2013
129
Beneteau 37 Oceanis Platinum Edition Seabrook, TX
Slam time!!
I have in mast furling and no problems for about 3 years.
First "READ THE DAMN MANUAL".
You'd learn a lot. The only failure I had was when the boom car exceeded it's design limits in a storm.
It may not enjoy the efficiency of a classic rig with vertical battens but makes up for it in other ways.
I'm 71. I have an elect. Winch to boot. Every line runs to the cockpit and every high tension line leads to the winch including jib furler.
First leave some slack on the boom via main sheet when furling and unfurling. When furling main; have boom at 90° or up to 2° above 90° to the mast. When unfurling have boom at about 2° below 90° to the mast. Maintain some tension on the main when furling to keep it snug like you would on a furling jib.
An in mast furled main has infinite reef capability which is a definite plus in heavy weather. Not being bound to the boom also allows you to fill the main in light winds. Etc.
Don't trash in mast. Don't trash classic. Don't trash external or boom furl. Just read the manual. Geesh.
Likes: BrianRobin
Jun 11, 2011
1,243
Hunter 41 Lewes
Bendintwos don't have Selden masts they have Zspar I believe with the worm spool for the furling line. Very different from a Selden. The Selden actually is gear driven to a single loop spool that sits on the outside of the mast and can be operated with a winch handle directly if need be. I'm not trying to pick on Beneteaus or Zspar but I believe the Selden furler is superior. I have used both as I have had both. Sail condition and your attention to proper furling per the manufacturers manual are the key. Having a modern light weight laminated sail is also a boon.
Mar 20, 2004
1,744
read the manual and pay attention to boom angle and has been said. We've never had an issue since switching to a laminate main. with a sail as worn and blown out as that it's lucky it happened in a marina instead of at sea.
My sailmaker shared an emergency trick with me - carry a set of welder's vicegrips - they have a large flat face at 90 degrees to the handles. If you get really stuck and can't work the sail loose, go up the mast to the stuck point and grab the sail with the pliers. pull out, and if needed continue up the mast until the stuck part is released.
JamesG161
Feb 14, 2014
7,752
In-mast is just a mechanism. The crew may be finicky.
The Admiral and I can unfurl our 17' 9" footed main sail in 2 minutes and furl it in 5 minutes. Smooth as silk.
I wonder why they keep making in-mast furling mains?
________
If you read this entire link, you will see a good discussions on how to resolve the mechanism and train the crew not to be finicky.
https://forums.sailboatowners.com/index.php?threads/in-mast-piece-of-crap-furling-system.175976/
:plus:
Jim...
Dec 19, 2006
5,821
Most newer sailboats come with in mast and also they love them and most do not have any problems.
2 things that cause problems with IN mast is a bad sail either blown out and baggie and the other is operator error,if you own Inmast they need to learn how to use it properly.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
I am still using my original sails on my 2002 H410 with Selden in-mast furling. I have had them professionally serviced and cleaned every other season. I have had no problems furling or un-furling ever since I recieved a tip from another Selden sailor to let the vang and the mainsheet loose for the furling operation. I do still set it off to port during furling, but allowing the boom to find its own position frees the sail to find its own level in the furling process.
Likes: JamesG161
Deleted member 117556
Have had IMF for 15 years on two different boats and most problems are related to technique furling it in. Despite all the years I have done this sometimes i still screw it up. It is always possible that the design of the IMF and/or the sail are incorrect or faulty but I have no experience with that. I will never own a boat without IMF but that's just my experience. Your results may vary...
bob
Jun 14, 2010
2,298
bob
Hi Bob -- The two sections that I bolded are incongruous to me. I can't grasp why it's so good to have that convenience -- especially when one considers the possible dangerous consequences of not being able to furl, coupled with my own experience that things are much more likely to fail at the worst possible times. I just hear too many stories about how finicky IMF can be, whether operator error or not. Add to that the fact that IMF sails are inferior (in shape) to non IMF sails for sailing performance, and that's why I'd never own a boat with IMF.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
I'd love to have in-mast furling. What a great way to douse a sail, or reef.
If it were guaranteed to work every time without fail.
Part of the consensus here for reliable operation seems to be proper furling technique, which may be elusive in an urgent situation with high winds and the increased likelihood of mistakes. As it is, I can drop the main even in high winds, and off the wind, then claw at it like a monkey scrambling up a tree to evade a leopard. Even if it jams on the sliders due to wind pressure, I still have the option of using the motor or weather-helm round up to get her somewhat into the wind and claw at it some more.
If it jams on a furler in the mast, the sail may be doomed, or other perils to the boat may be at hand.
This is just what it seems to me based on comments here, as I have no practical experience with in-mast furling.
1,243
Hunter 41 Lewes
you can turn into the wind with an IMF to monkey with it if there is a problem.
Nov 8, 2010
11,386
In-mast furlers are naturally more complex than traditional mainsails. And any engineer will tell you, all else being equal - when system complexity goes up, system reliability goes down.
These systems have gotten more reliable. But its equally true that their failure modes are spectacular. And that's why the vast majority of blue water sailors don't use them. When you put your main up and down once every week (or less) why put up with that? A lazy bag with a full batten main and an electric halyard winch make a great solution, with great performance to boot.
For everyone I know with a IMF, the biggest reason they like them is not having to deal with zipping the lazy bag.
Likes: Mark Maulden
Oct 13, 2013
129
I'm not pushing any style. That's your call.
I will say my in mast furl system has worked in severe weather conditions. I can reef single handed in a full gale with infinite adjustment. When the storm stressed my boom car to where the bearings exploded I was still able to limp through furling and unfurling single handed over more than a thousand nm. In various wind conditions and seas including gale force.
The furling system allows me to have full control on the main at all times.
What do you do when a classic system unzips from the mast? And your sail is laid out on the water?
Likes: BrianRobin
