Agree with John...more thoughts on 6 V batteries
I agree with almost everything John says, but would add that good golf car batteries can weigh more than 61 pounds. The extra weight is extra lead, which will either give you more amp hours per cycle, or more cycles. The reason that golf car batteries work so well is that they are designed for a huge market, indeed the ONLY mass market for battery powered vehicles. Technically, they differ slightly from a Marine Deep Cycle battery, but not in any important way. They are designed to be used hard, and in bumpy conditions, so they are structurally strong, as well. You can use a group 24 battery case, but the lid won't quite go all the way down. Finally, as a twenty-plus year slave in the golf industry, I can tell you that Trojan is the brand of choice...not Rolls, nor Surrette, nor any other. And, the best deals can usually be had from a golf car supplier, rather than a Marine Store, including West Marine. Good luck. This IS a no-brainer.
