That happens quite a bit, and it’s also possible that you moved out of range. It’s hard to know where the base stations are physically located.Maybe it's offline. I showed up a couple of days ago.
Unless you know better, I doubt "Satellite AIS" is an app. It’s more likely that the boat has an AIS system that updates via an on-board satellite data connection that I mention in my first post. The 6-latency is set to keep data costs reasonable.Further examination using VesselFinder, I could not find your boat with a MMSI or Name search. I did sea a boat anchored in the "Great Salt Pond" with no name. It had a location identified by "Satellite AIS" a new app that has a 6 hour latency but helps to locate vessels when they are out of range from land based systems.
Pretty certain it's a BoatUS issued number. It was acquired by the previous owner, and I was allowed to take it over.How did you register your AIS? You have an MMSI number 338206179. Is that a BoatUS provided number or a Federally issued number?
Are you sure, or is there a setting for that? There are a few class B sailboats around our marina that I routinely see, even when they're docked for extended periods.Normal AIS transmission for B class systems (like ours on pleasure boats) do not get recognized unless the boat is moving at at least 3 knots.
Cool. Have the same unit. One of the features for the XB-8000 is the frequency of transmission.my AIS unit is a Vesper XB-8000
Its reception service. If you’re remote, you still need a method of getting your data up and into the cloud.It is a subscription service through VesselFinder. https://www.vesselfinder.com/satellite-ais
Perhaps the term app was not used correctly. Rather expensive in my opinion, but useful for some folk.
It did identify jviss's boat as an AIS target but unless you subscribe to the service no boat data is provided.
