Blipping is BS
OK, now that I have your attention, my Yanmar 4JH2E manual says:"Idle the engine before stopping: 1) To stop the engine, place the control lever to the Neutral position and operate the engine at low idling speed for about 5 minutes. !Caution: If the engine is stopped suddenly at a high temperature, the temperature of various parts will increase and engine troubles may occur." No mention of blipping or shutting down at high speed. The manual does talk about low speed operation: "When the engine is operated at a low idling speed (below 1000 rpm) for a long period of time (over 2 hours), excessive carbon and fuel residue tends to accumulate due to incomplete combustion. Carbon deposits on the injection holes of the fuel injection valves, exhaust valve, and the turbine blades of the turbocharger, etc. cause a drop in engine output, knocking, and other troubles. To prevent these problems, be sure to blow off the carbon accumulations by full speed operation. Operate the engine at over 2500 rpm for one minute in every 2 hours of continuous low idling operation."It would seem to me that blipping the throttle is not necessary unless your marina is so large that you must idle 2 hours to reach your slip. I have practiced this with 4 diesel engines over the years, 1 Volvo, 1 Universal, and 2 Yanmars and have never had a single problem with any of them. I have a friend who blipped his brand new Yanmar 2GM20F on every shutdown. That engine died with severe overheating damage after only about 600 hours. My friend swore up and down he never overheated the engine or heard the high temp alarm. He doesn't blip his Yanmar now either. IMHO, blipping is not necessary and may actually cause overheating damage. As Calif. Ted said, how much of this is shade tree mechanics vs real world manufacturer recommendations? Just my 2 cents.
