cotter rings...
I used cotter rings on my Cat 27's standing rigging but switched back to pins. The advantage to pins is they can be easily removed. Rings, especially when imbedded inside a turnbuckle, can be a pain.Most people, myself included, install the pins incorrectly. The pins should be trimmed so that they are only 2-3 time the diameter of the cable. After the pin is inserted through the eye they should be slightly bent, just enough to keep them from coming out. It also makes them easy to re-use. Rigger's tape is then wrapped around the turnbuckle to protect the pin's ends from scratching anything. This is standard practice for all coastal and offshore sailing.That being said, on a trailerable boat I would probably revert to cotter rings just so I wouldn't have to tape and un-tape. On my Nacra, I use stainless hitch pins to clip the rudders, a locking pin for the forestay, and cotter rings for the shrouds. The shrouds are not disconnected for trailering, if they were I would use the locking type pins. There are no turnbuckles on that boat, but rather shroud adjusters. Locking pins and shroud adjusters may be a vialble option for you. Next time you are in the marina, take a walk around and look at some other boats for ideas. If you aren't sure what some of this hardware is, get a copy of a good marine catalogue so you can see a picture, rather than rely on a description.
