types of survey
There are a number of different types of survey you might commission. In descending order of completeness & cost, some examples are:1. Pre-PurchaseThis is the most comprehensive and in-depth type of inspection, and is highly recommended when purchasing a new or used yacht. This type of yacht survey assesses the structural and cosmetic condition of the yacht for a prospective buyer using non-invasive technology. This same report can be used for lending or insurance agencies. The purpose of the survey is to provide an overview of the yacht's condition , value, and suitability for the intended use. Emphasis is placed with regard to structural features; determining the seriousness of existing problems and suggested repairs. A moisture meter is used to determine if there is excessive moisture in fiberglass hulls or rot present in wooden hulls. The engine is assessed based on external visible inspection. If necessary, a more detailed assessment should be provided by a qualified engine surveyor. A sea trial and in water inspection is also highly recommended.2. Insurance SurveyUsed to determine the insurability of a yacht as required by your insurance company . This survey will provide insurance underwriters and other agencies evidence by which they can determine the yacht's structural integrity, its suitability for its intended use, value, and compliance with USCG regulations, ABYC or NFPA standards. The interior of the hull is observed, where accessible, and remarks are noted. Bottom inspections and sea trials are not performed unless required. This survey is not as thorough as the pre-purchase survey.3. Damage InspectionThis survey is performed to assess the extent of damage to yachts. Recommended repairs and estimated repair costs are provided.4. Appraisal InspectionThis survey is required for boat owners who are refinancing or applying for a second mortgage, determining a selling price, or donating a boat for a tax write-off. It is used to establish a yacht's value by setting a fair market value and by estimating the yacht's increased value by projecting a rebuild or refit.5. Preliminary Inspection:A brief inspection is carried out on the vessel, as lying without any preparatory work or dismantling. The observations obtained should indicate whether a full survey is justified.
