Why are my shaft zincs loose?
Jim
I'm a diver, so I get to take a peek at my prop, shaft and zincs frequently. I find that my zincs are usually loose so I tighten them up. Sometimes I tighten them up to the point I think that something will strip or break. But still,,,they loosen. anyone have this problem? Anyone have a solution. I suppose I could punch the threads but that would make it difficult to get them off. JIM
Nov 23, 2004
281
Columbia 8.7 Super wide body Deltaville(Richmond)VA
Hard rap
Jim. I was told to give them a good hard rap with a hammer upon installing them. This sets them well on the shaft, so that they won't tend to compress themselves back off the curve. I haven't had a chance to check whether it worked as my shaft zinc is gone after one year in the water. I can't tell whether the core is still there or not. Water is too cold to go diving, and I don't have a diving suit. I'll find out when I haul her.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
canadian zincs
I've had problems with the Canadian zincs coming loose several times. If you can find made in US and use loc-tite you should get better results. I think the threading is faulty with the Canuck zincs.
Ross
Jun 15, 2004
14,693
There is also the posibility that you are getting
metric size zincs from Canada. A 3/4 inch shaft will certainly look like a twenty mm shaft. But 3/4 is 19 mm, so a 20 mm zinc will be loose.
