SHELLAC – A TRADITIONAL FINISH
Common Shellac MythsMyth: Shellac is made from bugs or bug droppings.FACT: Shellac is a resin secreted by the lac insect to form a cocoon, much like a silk worm. It takes about 100,000 lac bugs to make 1 lb. of shellac resin. Myth: A shellac finish turns white when water touches it.FACT: Fresh shellac is remarkably water-resistant and, in most cases, will stay clear after hours of exposure to water, making it a great finish for most interior surfaces, including woodwork, trim, doors, cabinets, paneling, floors (yes, floors!) and furniture. Myth: Shellac scratches easily and is very brittle.FACT: Shellac is a durable finish that is much less brittle than lacquer and does not scratch as easily. Unlike polyurethane, a damaged shellac finish can be easily touched up or renewed by applying another coat. Myth: Shellac is incompatible with other finishes.FACT: Shellac will adhere tenaciously when applied over almost any other type of finish. When used as a sealer under certain polyurethanes, however, regular shellac may not be compatible because it contains a small amount of natural wax. To seal wood before applying polyurethane and other finishes we developed Bulls Eye® SealCoat,™ a shellac-base universal sealer that is 100% wax-free. Myth: Shellac turns an ugly dark color as it ages.FACT: Shellac is UV-resistant and does not yellow or darken with age. The dark shellac that people see in older homes is a less-refined version of shellac that either was naturally dark or was tinted by contractors when dark wood colors were preferred in the early 20th century. Myth: Shellac is an old-fashioned, outdated finish.FACT: Shellac has more modern features and benefits than any other wood finish in the world.ADVANTAGES1. Non-yellowing when compared to varnish and cellulose-nitrate based lacquers.2. Quick-drying. Many shellacked items can used the same day or shortly thereafter.3. Wide variety of colors available.4. Superior adhesion -- no other type finish can surpass it.5. Excellent hardness -- it can be sanded and rubbed out well.6. Excellent as a sealer coat to raise the fibers of the wood for subsequent sanding. Also seals in finishing contaminants such as silicone, waxes, dirt and oils.7. Ease of repair. Because shellac re-dissolves in alcohol, scratches and other minor surface imperfections can be invisibly repaired by re-applying shellac to the damaged area. The new shellac melts into the old shellac allowing for perfect repair work.8. Ease of removal. Old and new shellac can be removed with denatured alcohol which eliminates the need for harmful and toxic strippers.9. Can be wiped on (padded), brushed or sprayed -- all with good results.10. FDA approved -- safe for food utensils and children's toys.11. No unpleasant or toxic fumes.DISADVANTAGES1. It re-dissolves in alcohol so perfumes and strong alcoholic beverages like whiskey will mar the surface.2. Forms white rings on contact with water. This is more of a problem with shellacs that have wax and old shellac surfaces. 3. Tendency to show scratches. The resistance to scratches can be improved by a simple waxing. 4. Has a shelf life after mixed in alcohol. 5. Not resistant to alkaline compounds. Alkaline chemicals such as lye and ammonia discolors and mars shellac because of its acidic composition. These chemicals are frequently found in household cleaning products.6. Sensitivity to heat -- shellac starts to soften at about 150 degrees F. Hot items can mar the surface.Keep in mind that some of the disadvantages, like scratching and marring with alkalis, are easily repaired because of one of shellac's great advantages -- its ease of repair.
