Whole new installation, revisited
7
Grand Soleil 37 Sausalito
Hi Peggy,
OK, I'm ready to spec out a whole new head, order parts, and get to work. You might remember my original message about my Grand Soleil 35:
http://forums.sbo.sailboatowners.com/showthread.php?p=748284
I've read your book, a couple of times now, and it really is a great resource. Thanks!
So, here's where I am:
I'm going with the SeaEra pressurized freshwater flush w/90 degree output coupling. I talked with Vic Willman, and confirmed that I can use two separate third-party switches for the water solenoid and the macerator, and he thought that was a pretty decent idea.
A Ronco holding tank, but I can only fit a 10 gallon one in the place where the tank is now. I might be able to go to 16 gallons if I move it somewhere else. That's pretty darn small, eh?
Trident hoses. Still have to work out sizes and lengths...
A new deck fill pump-out plate. The one that's there is 1.25"ish (metric I think), frozen shut, and leaks a lot when it rains. I'll find a nice new 1.5", and fix the installation so it's nice and solid, and doesn't leak.
I have a .75 inch vent on the deck, just one. I have to drill a 1 inch hole in the hull, above the water line for the other vent, right? I'll get a pro to do that.
And I want the option of pumping overboard, beyond the 3-mile mark. This will involve replacing the seacock too, it's weird and messed up. By weird, I mean it's a pass-through configuration with 2 big hoses. By messed up, I mean it won't close fully at the moment. D'oh. I'm wide open to suggestions on how to configure this.
I've decided against a Purisan or similar MSD. I'm berthed in an NDZ, so there's little advantage.
Does this all sound reasonable so far?
Thanks!
Sep 4, 2010
7
I'm having a heck of a time finding the right tank, and now I'm worried about the clearance needed on top for the hose connections. Are 90° elbows acceptable for the connections to the top of the tank? If so, then 3" should do it, right? or maybe 4"?
It's starting to look like I'll need a custom tank.
Thanks!
Dec 2, 1997
9,010
- - LIttle Rock
We need to talk...
This is more complex than I can manage in a forum setting. We can accomplish more in 20 minutes of phone conversation than we could by spending several hours reading and writing 10 emails apiece...so email me and we'll set up a time to talk.
Sep 4, 2010
7
Re: We need to talk...
Thanks Peggy! I'll get my notes together, and maybe get some photographs ready too, in case that helps. I'll email you shortly...
