I knew I spilled a little deisel when I opened the fuel filter. But didn't think I spilled that much. It is not leaking now - I've checked with papertowels under filter for several weeks.
But what little I did spill made it's way to the bilge and has coated bilge and fouled water there. I pumped bilge prior to knowing there was a spill, and water outside of boat had a slight sheen Turned off pump as soon as I realized what was happening. Have been emptying bilge since then with a turkey baster.
Does anyone know of a good bilge cleaner (home recipe or bought from Marine stores) that will clean the bilge of deisel? When placing fouled water in plastic water bottles, you can definitely tell it has an oily top layer.
