White smoke, reduced RPM, increased fuel consumption
weinie
Sep 6, 2010
1,297
Oh crap! Youre right! That adapter DOES look like it should fit. Let us know how it works and what readings you get.
May 28, 2009
764
Hunter 376 Pensacola, FL
Probably won't help much
But I thought I'd throw this out there anyway in the small chance that it might actually do some good. Are you sure your smoke is white? The only reason I ask is because a couple of years ago, we had a problem with increased fuel consumption and decreased power under load, and we were getting a bit of smoke, but it was a light gray color, and not pure white. Turned out to be the final stages of a plugged exhaust elbow. Replaced the elbow, and viola, the smoke went away, the power came back, and the fuel efficiency returned to normal.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Hi Robert,
That's an excellent suggestion, thanks. I thought of the elbow when I was going down the path of thinking it was raw water flow. I haven't looked yet. I replaced the elbow in 2004, I think. I wonder if it coul dhave become clogged up in that time.
The smoke looked pretty much white.
jv
jviss
Feb 5, 2004
7,089
I will. I actually read the manual that came with the compression tester (duh)! It's quite good. Only one question. The procedure, in summary:
  • warm up engine for 10 minutes;
  • remove all the injectors (or glow plugs, if that's where you're probing pressure);
  • fuel solenoid off - or, in my case, fuel shutoff cable pulled out;
  • "speed pedal all the way down" - which I imagine translates to full speed in our case;
  • install gauge, crank for 8 revolutions. Note max pressure and speed at which it came to max pressure;
  • repeat for all cylinders.
My question is: why max speed setting?
Thanks,
jv
weinie
Sep 6, 2010
1,297
Thanks,
jv
Because the manual was printed in China where the kit was made??!?!?!?
Likes: Amos Cape
