White Smoke on Startup
YVRguy
Jan 10, 2013
479
Hunter 34 Vancouver, BC
I have a Yanmar 24hp diesel engine. When I bought the boat the previous owner explained that this particular engine does not have a glow plug so full throttle must be applied on startup to put fuel in the cylinders. This results in an embarrassing cloud of white smoke. He said this was normal. Someone else recently suggested this is not normal and that I might need to have the injectors serviced. Any thoughts on this? I don't know much about engines (as you can tell).
Thanks!
Jun 9, 2008
1,792
- -- -Bayfield
One reason for white smoke upon start up is water getting in from the engine cooling area to the cylinders and it goes out the exhaust in the form of steam. This usually is because of a bad head gasket, warped head, etc. Might not be your problem, but might be too.
615
Morgan 415 Out Island Rogersville, AL
My perkins doesn't have glow plugs. I've never had to give it throttle to start it. However, the engine does get used regularly.
Tim R.
May 27, 2004
3,626
Agreed. Not normal. PO was misinformed or lying. Did this not show up on the sea trial?
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
Sorry but I don't have the time to prepare a thorough response but I can say that I suspect you have a 3GM30F, which I do as well on my H35. I really don't remember if it's related but I replaced my injectors myself....if that's the problem. Only cost was injectors and it was an easy (for me) job and I am not mechanically inclined...just ask my sons!
May 24, 2004
7,164
CC 30 South Florida
No it is not normal but it is a true and tried method to start an engine that may have lost some compression due to wear. In the absence of a glow plug, compression is what heats the diesel fuel to ignition temperature. Compression is usually built up in a handful of revolutions to its max but in a worn engine a quicker cranking sequence is required to provide more revolutions and that is accomplished by increasing the throtle. The white smoke is just the burning of the excess diesel fuel that was pumped into the cylinders during the cranking sequence. When talking about compression I like to talk about oil grades. A good indicator for the condition of the engine is how thick the oil may be. A thicker oil may disguise the loss of compression in a worn engine while a thinner oil may cause a fairly good engine to smoke some. Another thing to take into consideration is ambient and water temperatures. It is harder to crank an engine in cold weather as the oil acts thicker and it takes longer to reach fuel ignition temperature. Even a good engine can benefit from cracking the throtle at startup in cold weather. Batteries are weaker and there is more friction in the engine so you will need more revolutions quicker. I could not help notice that it may get kind of cold in your part of the world. If once it starts the engine runs good and does not burn oil I would not worry to much about it as probably has many years ahead of it. If on the contrary it runs rough, lacks power and burns oil then it might be in need of a partial or complete rebuild.
Nov 6, 2006
10,054
Doug, I suspect you have a 3GMF like the one in my 34. Have you tried starting it with the throttle just cracked a little? I've never heard the "full throttle" story for starting.. Here, the temperature is rarely below about 50 F in the boat, but the engine always starts by the second or third revolution and many times it will start on the first cylinder to come to compression...
NYSail
Jan 6, 2006
3,136
Beneteau 423 Mt. Sinai, NY
Maybe I didn't read it but have you tried starting the engine Normally to see what happens? I to. Have a yanmar.... I push the throttle up about half way then back to idle and then start . No white smoke
Sep 4, 2007
776
Hunter 33.5 Elbow, Saskatchwen, Can.
I use about 1/4 to 1/3 throttle for start. No smoke. I would give that a try before digging to deep. It could very well be low compression on one or all cylinders. If it still smokes maybe time for a friend or mechanic to look at it.
Good luck.
Islander Freeport, 41 Ketch Longmont, CO
I have a 2GM20 which puts out a mix of white/black smoke, usually the black is if I try to over rev when starting. Before my latest fix, when I started the engine, I would have to crank it a while, push the throttle to full open crank some more and finally it would catch on 1 cylinder. After loping along for a few cycles, the 2nd cylinder would fire and she pured like a kitten. Until then I got lots of smoke, etc.
PO always had these problems gettig the engine to start, Over a period of a couple of seasons I treated the fuel, fixed the water pump and this season finally solved the starting problem, the fuel lift pump was leaking. I noticed a slight drip at this pump which turned out to be the fuel lift pump. After tightening the 4 screws on this pump the engine starts almost immediately and complains if I provide too much fuel too soon.
I think I'm still starting on only 1 cylinder and so still have some work to do but, its nice not having to crank too much.
Check all fittings in the fuel delivery system from fuel tank to injectors and back. Make sure everyone is tight and not leaking (or seeping). Air in the system even the smallest amount may be a source for your problem.
I'm no diesel mechanic so this may not be a true source of the problem but, the more I learn about these engines the simpler they are. Fuel, compression and air and they fire every time. If they don't start immediately something is wrong.
Good luck and I look forward to others with more knowledge.
Victor
Likes: mnmpizza
Jun 6, 2006
6,990
the white smoke is normal if you are using full throttle to start. It is the unburned fuel from the few strokes that did not get hot enough to ignite. the issue is that either the cranking is not fast enough or the compression is lower than normal.
Does it crank OK, ie at a normal speed? does it do this after it is warm?
if the crank speed seems ok then I'd do a compression test and see what that revels. if the crank speed is not ok then check all the high current connections. if they check out pull the starter and test the commutator for a short across on set of coils.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I hate when people say "throttle" when talking about diesel engines. Of course, there is no throttle, there's a speed control.
This comment is particularly bothersome:
...a quicker cranking sequence is required to provide more revolutions and that is accomplished by increasing the throtle.
How?
YVRguy
Jan 10, 2013
479
Thanks all.
- I have to use full throttle in winter time with temps sometimes down near freezing. I bought the boat in winter so admittedly I may be using a winter starting technique when in summer it needs less fuel
- If I've had the engine running for a while it will start with no throttle and no smoke after that. Even after being stopped for a few hours.
- The problem may have been exacerbated by my electrical issues with the starter which I finally fixed by installing a relay. So with the engine not cranking reliably I may have needed more fuel to get ignition.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
White smoke equals water, could be a head gasket, or worse, a cracked block. Look at the crankcase oil, if it appears milky, that could be a cause. Since oil floats on water, if you could get at the drain plug, you could open it to see if water comes out first.
As far as starting, the most I have ever had to do is open the throttle slightly, and the engine will start in just a couple of revolutions, even after setting all winter (Yanmar 2GM20F).
WayneH
Tartan 37 287 Pensacola, FL
Sounds like you've got the answer.
You might try a "hot" start next time just to see if you REALLY need to start with full throttle. Yeah, I know "throttle" is not the right term but it works. :)
Oct 17, 2011
2,809
Ericson 29 Southport..
Uh, if not throttle, then what WOULD it be? It's not gas pedal. Or an A.F.U. like on a plane. Certainly nothing artificial about mine..
jviss
Feb 5, 2004
7,089
I know this thread has gone cold, but this terminology intrigues me.
A throttle is a device to choke off the air flow to an engine. In gas engines this also reduces the fuel flow, usually because the carb is a Venturi device.
On a diesel your speed control in the cockpit is controlling the speed setting of the governor, and the governor controls fuel delivery to keep the engine speed in regulation. Thus, no throttle.
Ross
Jun 15, 2004
14,693
cold weather starting on construction equipment makes lots of white smoke until the engine gets hot. My little Volvo blows a cloud of black smoke on a cold start at full throttle and will start on the second turn, at idle, in gear, on a hot start.
Oct 17, 2011
2,809
throttles.
Actually, my question was genuine, and now I'm thinking it was misconstrued as sarcasm. I suppose that's an easy enough assumption, bearing in mind who said it. But I don't think I've ever heard it called anything else but throttle, and in the definition it seems like the term may be slang. Interesting.
And an old dog DOES learn a thing now and then..
And one more thought, I've dealt with countless numbers of diesels in my life, and any kind of smoke at start up has never alarmed me. I'm not saying it should, but I've seen a thousand of them that did. It's what they do when it gets warm that I'm making a life decision on. Its life..
