On my 85 Catalina 30, I have noticed the last few times I have started it after it sits for a month or two that there is a fair amount of visible white smoke that will come out of the exhaust for the first minute or so and then it disappears and the exhaust is totally clear. I know that water in the fuel can cause white smoke but if it is only the first minute when the engine is cold is that something others have observed, too? And I've noticed that even under full load the engine temp won't get above 120 degrees or so- I guess better too cool than too hot but I believe that the correct operating temp is closer to 150-160 and it may be time for a new thermostat? Thanks in advance for your advice!
