Sorry, jimq26, bue your whisker pole is limited to
your "J" dimension (the distance between the front of the mast and the attachment point of the headstay). SOME one design fleets allow longer whisker poles, and PHRF will allow a longer whisker / spinnaker pole with a handicap penalty (in LMPHRF, it is 3 seconds / mile for each 3% (or less) that the pole exceeds J), but your max whisker pole length without a penalty is the same as your spinnaker pole length and is equal to your "J" dimension (WWW.LMPHRF.org).As for adjustable whisker poles, you CAN use them as long as it is either banded at the maximum extension and / or limited by a mechanical means (such as connecting the ends together at the J dimension with a nonadjustable length of wire). (again, see LMPHRF.ORG)As for citing the exact rule that was broken in a protest, there is NO requirement for the protesting boat to get the rule correct (see The Racing Rules of Sailing), (the protest committee decides which rule (if any) was infringed), but the protesting boat MUST file a valid protest (hail the offending boat, fly the protest flag, and file the written protest within the time limit) for the protest to be heardSteveAlchemist C-320 #909p.s. my whisker pole is banded while a friend has both banded and limited the extension on his using a wire)
