Whisker Pole
Sean Coerse
I got a steal on a line control Forespar whisker pole for my H240. I need to know which mast ring to use on my Z-spar mast. Also what height from the deck level did you install it. I dont plan on putting the ring on a track at this time, as the H240 only uses one jib. Any advice would be appreciated.
Michael Bell
On my H26...
I installed a whisker pole ring on my H26 so that the whisker pole was horizontal when in use. Also installed a pole clamp above the ring so that when not in use, the whisker pole just snaps in place on the front edge of the mast – ready for use.
