whisker pole
4
Oday 272 Merritt, nc
Need help and suggestions for attachment to the mast.And also to the clew.
For the clew should I attach the pole to the sheet or to a ring on the clew?
gpdno
May 16, 2011
144
Watkins 27 Venice
I have mine attached to a small loop of cord that is on the sail clew.
992
Oday 25 Gibraltar
I have a small line with a snap that I attach to the mast pad eye on my inboard end so I don't lose the pole overboard from fumbly fingers. The pin on the outboard end would go into the eye on the clew. Tension pulling inboard from the sheet is usually sufficient to keep it place.
Rich
Nov 8, 2010
11,386
Rich
Thats if it has a pin. I'm guessing on a 27 it has jaws both sides. If that is the case, clip it to the sheet, jaw facing down.
For the mast side, you should have a pole ring, or better yet a pole-ring track mounted to the forward part of the mast. Like this.
http://www.forespar.com/products/mast-pad-eye.shtml
