whisker pole
May 7, 2006
249
Catalina 28 Mark 1 New Bern
looking for a whisker pole for a catalina 28. I am located in Nc and will travel reasonable distance.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
What head sail are you flying or how long is its foot?...........pole length should be 100% of the foot of whichever headsail is being flown or J dimension (if you have the original 100% sail your J = 10.8 ft). If it is not a 100% jib measure from the tack to the clew and the whisker pole should be this length. You need to have some overlap in the pole. Forespar recommends their HD 7-15, #407101 pole for your sailboat Size Recommendation Guide (forespar.com) and new cost from these sites FORESPAR Heavy-Duty Telescoping Twist-Lock Poles | West Marine, Forespar Pole ADJ 7-15 Alum Whisker Pole (velasailingsupply.com), etc.
You can find used whisker poles on these sites: Spinnaker and Whisker Poles - Used Boat Equipment AND Spinnaker Poles Used - Sail Exchange
1,654
C&C 40-2 Berkeley
Just remember: whatever distance you are willing to travel you can get there faster with a whisker pole
  • Ha
Dave... necessity is the mother of invention.
sidw
May 1, 2006
15
- - newport, ri
Actually, if you are racing, the max length you can use for a whisker pole is usually the J length. If you have a longer, adjustable pole, it needs to have a black mark at the max J-length, and, yes, it will probably be suboptimal for a larger sail. Many people use a spinnaker pole for the whisker pole.
Ward H
Nov 7, 2011
3,795
I have a 6'-12' Forespar whisker available. Aluminum ends. Came off a 25 O'day. May be a little short for your boat.
Too far a drive to pick up but can be shipped if interested.
Nov 1, 2017
635
Hunter 28.5 Galveston
I.M.O.: Make sure you don't buy a telescoping whisker pole. Weather and salt will work its way into the sleeve between the telescoping parts over time and become an oxidized nightmare to deal with. A few sailors I know do use them, but they make sure to take them apart and clean them several times yearly. This is a hassle. Single-piece aluminum forespars are also usually cheaper. Like Dave said, a boat hook pole works fine until the weather starts to kick up. Once gusts start getting to around 16-17 kts. you'll want something a bit beefier.
