Whisker Pole size for Hunter 30
Dec 23, 2019
5
Hunter 30 Suamico, WI
Looking for a used Whisker Pole for a Hunter 30 155 Genoa. Looks like 10-18' telescoping is recommended. Very expensive. Any suggestions for maybe an adjustable vs line control and would 15' be acceptable vs. 18'
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
You can run any size u want as long as your not racing second hand stores best place to get one. But if ordered off internet shipping very expensive
As long as you are not racing 15' would suffice over 18'. What the pole length does is to push the crew out enough so that the sail has as close to its foil shape as possible. So given that, the length should be close to the foot length of the sail. It's also desirable to be able to collapse the pole so you can swing it through aft of the forestay for jibes. They are expensive. They are also very useful for downwind sailing. If you scour the local boat yards you may find a mast, boom, or pole that could be cut to length. It doesn't have to be absolutely stiff so you can keep it on the lighter side. Before someone in our fleet gave me one, I used a telescoping boat pole. Certainly not ideal but better than nothing.
dLj
Mar 23, 2017
4,847
The original spinnaker pole on my Cherubini 30 is 14 feet.
dj
