Looking to add mast mounted fixed ring whisker pole mount to my boat.
To date, I have not been able to find suitable unit as the foreward edge of
the mast is 'almost' flat and the mast has a conduit mounted inside. Have
found many rings with rounded or curved mounting bases that are not the
correct diameter and have found a few units that have flat bases with
vertically centered mounting holes. The centered mounting hole would creat
a problem with the internal conduit. Do you know of a unit that has a flat
mounting base with two or four mounting holes on the side of the base?
Looking for a solution.
