Which Model Cable Tensioner for a Hunter 23
Mar 8, 2015
4
Hunter 23 Ohio
All-
Being a novice, I was not aware that I was supposed to use a tension gauge when rigging our new Hunter 23. It was suggested that I look into Loos models, but I am not sure which one is the best for my application?
Anyone have any suggestions?
Thanks again-
Ryan
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you go to the loos site it may tell you what size you need by the cable size on your boat
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I have a 23 and don't use a gauge (if I had one I'd use it, but they are quite pricey).
I just follow the tightening/centering procedure (uppers first, then lowers) and do it by feel - if I can pull on the shroud and it moves maybe a half inch or so, I stop. I do check the leeward shrouds when I first sail with enough wind, and so far I have not seen any looseness.
Dave Condon has published more details on the procedure.
