The parts are $350 to replace my split backstay. I won't have the money for that until The end of may. I have a synthetic 1/4" winch line I want to use as a backstay until then.
It is 100' long. I am going to use a cowhitch at the top so I will have two lines coming down. There is a pin at the point where the split in the backstay meets. I am going to tie to that pin.
So I have two ropes that will terminate at the pin. What is the knot I should use for this line. This synthetic line is kind of slippery. I have been using it as a halyard but it sucks for that mission because it slips on the winch.
Can I tie two lines into a buntline hitch that has two lines following the same path, or should I use a fishing line knot because of the slipperyness of the line? But will the fishing knot work with two lines in it?
Obviously Saildog and Ross have the answers if you've been following the other knot thread!
I'd like to see Ross and Saildog face off in a knot tying contest.
