Which Hunter 25 is this?
-na -NA Anywhere USA
Go to upper left and hit the three lines next to the sailboat emblem. Scroll down to boat info. Go to hunter resources. Pick 25. You will get two boats listed but look for the year 1973-1984. Go under boat manuals, look there. You can look thru photos andowner mods. The old 25 came in a fixed keel or swing keel
Jul 1, 2020
15
Hunter 23.5 Boston
Thanks! I found the drawing of the one with the 3 portlights. Looks like a 6 footish cockpit. It seems there were versions with 2, 3, and 4 portlights in the 70s/80s?
They stopped building that 25 as I came on board as a dealer in 1984. If yo refer back to the beginning of this Hunter owners thread, there is one called hunter resources archive on line. Glean thru that.
I would also post your questions under Small Boats or Cherubini Hunters. The first 25 was designed by Cherubini but I have seen posts responded by his son.
Hope this helps
1,610
Here is a link to the manuals: HunterOwners.com downloads
Note that during the ten years of production, 1973-83, there were two different cabin profiles, and several window layouts. But they are all the same basic design, and I doubt there is any variation in cockpit layout.
