Which Caulk for Keel Bolts
Nov 14, 2013
16
Beneteau Fist Midwest
I pulled the keel bolts from my 1984 Bene First 35. Each bolt is well bedded in caulk. The seal was very good, and each bolt is in great shape. I plan to apply proper torque to the bolts, while the boat is in dry dock. Is there a special caulk that should be used for bedding the keel bolts? I use SikaFlex 291 for other projects quite a bit. Is this caulk good to use?
Thanks in advance for the help.
Sep 23, 2009
1,476
Any caulk is better than no caulk
For keel to keel stub or hull to deck I would use 3M 5500, for just the bolts and thru hulls I use Life Caulk or the Silkaflex 291.
Glad you are checking the torque, most owners just ignore them-sad to say.
Nov 14, 2013
16
Thanks for the reply.
Last winter, I just resealed the keel/hull joint, without tending to the keel bolts. Upon haul out, there I found a couple of small places where the seal on the keel/hull joint pulled apart. One place was on the very front of the keel. Then there is a length of about one foot on one side of the keel/hull joint that pulled apart.
This winter, I plan to rebed and torque the bolts, and then reseal the keel/hull joint with caulk. Then inspect the keel/hull joint upon haul out next winter. If the seal on the keel/hull joint is broken, I plan to have the keel/hull joint worked and rebedded. Does this sound like a good plan?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
yes sounds good note that the 3m sealant should be 5200 not 5500 i think that was a typo on the above post
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Don't use 5200 if you ever intend to take the joint apart. Its a good adhesive , maybe a bit too good.
Dec 4, 2013
22
Hunter 27 Lavilla Cove Marina
Purchased an '80 Hunter 27 last year. I was concerned about the keel bolts so had the boat pulled for the purpose of inspecting the keel bolts. Keel was bedded with 5200. After the keel nuts were removed it required yard personnel over two and one-half hours of chiseling to finally break the keel from the hull. All bolts were in perfect condition. Moral: 5200 is not known as satan's glue for nothing.
Feb 8, 2013
92
beneteau 352 Raritan Bay
+1 on the Life Caulk.. my boatyard recommended it for below water applications
