The general rule of thumb is to use the more flexible battens in light wind and the stiffer battens in heavy winds. The ultimate determination will be sail shape. You want a smooth transition from the forward end (the flexible end) of the batten and the sail. If there is a kink at that point, the batten is too stiff for the given wind conditions. The leech should have a straight exit.
