Where's the forestay turnbuckle
G
Glen
I'm mounting a "on the level" radar mount on the backstay. I thought I'd have enough play in the backstay turnbuckles to ease the backstay but no such luck. I've eased them all I dare but they're still tight. I tried several schemes to pull the tension off but no luck there either. In my Hunter info there's no info on the roller furling and no identification on the drum. I'm thinking there's got to be a turnbuckle in there somewhere but WHERE? I've got a 1994 37.5. THIS FORUM IS GREAT! I really appreciate all the information I've gleaned since I bought the boat last November.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Your problem is NOT in the headstay turnbuckle. What you need is more tension in your cap shrouds. Changing the headstay length is ONLY for adjusting mast rake, nothing else!! What you need is to bend the masthead back. Pull on your backstay adjuster and take up tension on the cap shrouds. You should have plenty of distance in these turnbuckles. Attach the main halyard to one of the backstay anchor points and crank on the tension. Then release the backstay adjuster and remove the backstay.
C
Claude
Turnbuckle
Glen, Alan description of your problem could not be more exact, however for reference if you want to look for the Turnbuckle, assuming you have a below deck mounted Hood 810 furler (or similar unit), here is the way to have access to it. Remember it is easier done with no head sail on the furler. Part number refer to drawing on the related link. 1.Remove the tack socket Hex screw Part # 3 2.Remove Forward tack socket. Part # 2 Straight pull. 3.While holding the aluminium furler extrusion with one hand, Remove aft tack socket Part # 1. Let the extrusion go slowly. The extrusion will move downward about 6 inches with the tip resting on the turnbuckle. While you are doing so, pull the extrusion back up and check the lower part of the aluminium extrusion to make sure it is in good shape. It is a common occurence on these units that the aluminiun will crack around the holes close to the bottom of the extrusion. 4. Underneat the furler assembly, in the anchor locker, disconect the pin trough the hole in Part # 16 This is usually considered the difficult part in this operation. 5.Attach your jib haylard to the jib D Shakle part # 5 6.Pull Halyard and lift the complete furler assembly to expose the turnbuckle. To reassemble do the reverse procedure, the tricky part will be to put back in place the pin in the lower furler drum. The trick is to make sure the cavity in the centery clamp assembly Part # 18 is located exactly in line with the pin location. Some people told me it took them one hour to put the pin back in place. If everything is line up properly it is a 2 minutes job. Look at this web site for complete description of the parts, parts numbers and line drawing. This complete procedure should not take more than 10 minutes. Sounds complicated but it is easy. Good luck.
G
Glen
Thanks
Thanks Alan & Claude. Very helpful advice. Too bad we're not a little closer so we could meet up some place.
