G
George
Got a new to me '76 Catalina 27 with a Par marine toilet. Doesn't seem to want to work right - as efficiently as I would expect. After reading your recommended list, I suspect a lack of lubrication (squeaks and does not allow handle for pump to move easily up and down, a lack of priming, a lack of who knows what else. The holding tank looks to have about 2-3 inches of stuff in it, and thus far I have nothing to indicate that a dangerous back pressure has built up. Similarly it is not clogged, etc. In essence the almost ideal time to do whatever needs to be done to get the system working right. Last owner could not tell me which position was for dry and and which position was for wet bowl ( one is straight up, the other is about 20 degrees toward the front of the MSD if one is seated on it. Any advice on getting it properly working in the first instance and what the settings are? Prior owner says he recently rebuilt system.Thanks in advance for your help.George
