I had put one on a 21' San Juan
and it was placed at the bow well ahead of the swing keel. I tested the location by filling the place with water and once I ascertained I was getting a good reading I pumped the water out and dried it. I then laid a pool of epoxy and stuck the bottom of the transducer down in it. Once it dried it held the transducer in place and allowed a perfect signal to go through. Make sure you have no air bubles. I tried setting one up on a powerboat but apparently the hull was porous as the the depth/fish finder could not transmit through it. The transducer had to be replaced for an outboard one.
