got a smoking deal on a used high output alternator(balmar 7 series 80amp) and voltage regulator. Just trying to figure out a place to put the regulator.
Obvious place to install is in the engine compartment close to the alternator. Hopefully heat isn't going to be an issue for it? Directions said to place it where there was the least interference with stuff like the inverter (which is on the other side of the wall to my engine compartment)
Think it will be fine in there?
thanks,
Jared
thanks,
Jared
