Has to be a 751 or 752
They were the only manual toilets that Mansfield (which became SeaLand after SeaLand Technology bought Mansfield in 1984) ever made. SeaLand discontinued manual toilets altogether shortly after they bought Mansfield. Parts were available till the early 90s..then they were discontinued too.A Jabsco joker valve should fit your toilet. I'm guessing it will because till a few years ago, Jabsco offered a "universal" rebuild kit that fit several obsolete toilets, including the Brydon--which was a version of the Jabsco manual that was made in Canada, also discontinued about the same time as the SeaLand manual toilets--the Mansfield/SeaLand 751/752, and one or two others. However, I suspect that after 25 years, your toilet needs a lot more than just a joker valve to work efficiently again...seals, o-rings gaskets, etc have got be badly worn, even if replaced while they were still available...'cuz that would make 'em at least 10 years old. The inside of the pump cylinder wall has to be scratched and scored by salt too. You haven't said what you expect a new joker valve to cure...but I'm not sure it's worth spending even the $8-10 that a joker valve costs for a toilet that old. IMO, you'll be a lot better off biting the bullet and replacing the whole toilet. Your best choice is a Raritan PH II...about $250, which is twice as much as a Jabsco, but the only manual toilet under $500 made today that won't fail in a year or two.
