Where is the response of the expert
Jim
? was I expecting too much? I've reefed. dropped the traveler, etc but the Vision 36 is, in effect, a big (humougouos?) dinghy with special handling charateritics = where is the "expert" response, with the caveat, upfront, that this is a specialized question?
C
Chris
Are you sure it was plugged in?
Are you sure it was plugged in? This happened to me once with my cable box...it wasn't plugged in!
C
captbill
The fuse
Yep - I'll tell ya Jim - it's gotta be the fuse! You've got it in backwards! Bill on STARGAZER
Jun 13, 2004
43
Hunter 42 Key Largo
Check the switch
If the fuse is ok, then check that the 'Expert' switch is in the up or 'ON' position.
Feb 9, 2004
311
Specialized question
Hi Jim - With the caveat that the Vision 36 isn't exactly known for performance (the unstayed mast has a tendency to bend off in high winds), what exactly is your specialized question? We're here to help (or try to)! Not an expert, Trevor
