ONE MORE THING TO TRY
Eric: Don't feel bad, we all had to start somewhere and I don't want to remember some of (what later turned out to be) "dumb" questions I asked sailing friends when I first got my H31 in 1986. Getting back to your problem, there are a couple things. One, is the pump working at all? The reason I ask is that at the beginning of the season I always have a devil of a time getting the pump to take a prime when I refill my empty tank. I suspect that is not the case since you've not mentioned it before, but I throw that in FYI. Second, there is a slight chance you've got an in-line fuze between the circuit breaker and the pump. I've not checked mine, but will do so today. If you find such a fuze, hopefully it is blown and you will have water pressure back when you fit a new one. If not, then yup, you'll probably be contributing to your local chandlery! As an aside, just for this possibility, a few years ago I added a fresh water foot pump and spigot to my galley. Took water from a "T" just prior to the pump. This way if the D.C. pump ever dies, at least I'll have cold water. It also allows me to quietly pump water for morning coffee w/o waking my first mate with the noise of the pump! Good luck!Tim L. (S/V "TIDE")
