Where is the blown fuse?
F
Frank Maier
Dear Sirs: I purchased a standard Cold Machine in the late '80 with a horizontal Freezer unit SFH-1, the Compressor unit is a CM-12 type. My problem is that neither the Fan nor the Compressor will start. One weekend all was fine and the next weekend nothing worked. The unit was on while I was absent from the boat. I noticed that the tube connections face to my front, while the electrical connection face the back of the unit. and since these electrical connections are close against the hull, I find it very hard to see wether or not the fuse has blown. I noticed your latest designs have corrected this problem by having the electrical connections face the same way as the tube connections. Please email me instructions with drawings, if possible, on how to get at the fuse for replacement. My owner manual mentions the fuse, but provides no sketch nor instructions on the subject of fuse replacement. What a pitty! Also, please tell me which Controller model would I need, in case the fuse is not the problem. Thanks, Frank Maier
G
Gary
Fuse
The fuse is on the control module (black box all of the wires lead to). From 1983 till 1987, the 102N3115 module was used and the 10 amp BUSS type fuse is under a black screw cap on the front face between the heat sinks. From '87 till '93, the 102N3016 module was used. The 15 amp automotive type fuse is under a gray plastic cap just below the 12VDC connections. The replacement for either module is WAECO Adler/Barbour's AB3016, but before ordering a new module, make sure the compressor is not shorted. Let me know if it's not just the fuse and I'll give you the resistance readings for the compressor. Gary
F
Frank Maier
Thanks Gary!
Thanks Gary, I guess I will have to remove the unit partially, without disconnecting the gas tubes, to get at the fuse and its screw-cap. My manual talks about a 10 amps fuse, do you know what kind of screwdriver I will need; maybe I can change the fuse blindly without disturbing the unit. A photo/picture of its exact location would have been super. Regards, Frank
